La session d'avril de Demandez le Programme! aura lieu le jeudi 26 avril de 13h à 14h en salle Gilles Kahn du bâtiment Alan Turing et sera animée par Olivier Grisel (Parietal).
Kubernetes is the most popular container orchestration system. It is typically used to deploy applications and batch processing jobs on a cluster of machines, either on a public cloud or on premises. This presentation will introduce the main concepts and demonstrate its use for deploying a Jupyter Hub service that can be used by data scientists to run interactive distributed computation with dask on a cluster of machines shared with other data scientists.
