jeudi 16 mai 2024
« A deep dive and code from scratch to better understand how React hooks work. It talks about JavaScript fundamentals like closures, module pattern, ... It has been partially reviewed by one of the React creator, Dan Abramov and turned since into a talk. »
vendredi 31 mars 2023
« Spotted on the Haskell documentation about monads, this post gives interesting and visual explanations about applicatives, functors and monads. A little background on functional programming (and Haskell) may be needed, but the drawings should be quite insightful for most of the curious readers. »
TypeScript 5.0 is out [Laurent Steff]
« TypeScript 5.0 is now available, with some changes as: standard decorator support (it was experimental before), const parameters, real union enums ... »
jeudi 5 janvier 2023
« This (old) article explains briefly the Actor Model, a design pattern to achieve concurrency. It discusses also about Erlang, and the "'let if crash' philosophy". »
jeudi 20 janvier 2022
« Mixin, Module, Observer, ... most of the patterns useful for web application development are accesible on this website, with interactive examples. »
jeudi 13 janvier 2022
« In this video, Stephan Karpinski, a co-creator of Julia, explores one of the reason why there seems to be a lot of code re-use in Julia community: the multiple dispatch. »
Free your C++ functions [Laurent Steff]
jeudi 9 décembre 2021
« Klaus Iglberger's own and SOLID (pun intended) approach on Scott Meyers' recommendation in Effective C++: "Prefer non-member, non-friend functions". »
lundi 10 mai 2021
« This second parts about Mixins introduces 'Mixin classes' in C++, compared with the Curiously Recursive Pattern (CRTP). »
lundi 10 mai 2021
« Sometimes Design patterns have different names depending on the programming languages, sometimes not. Today I would like to share with you the 'Mixins'. This first part describes well the JavaScript Side. »
mardi 2 mars 2021
« The journey of what happens from a simple Eigen Vector addition in C++ to assembly. From high level like Template MetaProgramming, Curiously Recurring Template Pattern or traits, to low level like alignment and Streaming SIMD Extensions (SSE) intrinsic functions. »
mercredi 10 février 2021
« Eric Eliott gives some examples about object composition in JS. »
Modern C++ design patterns [Laurent Steff]
lundi 25 janvier 2021
« This article, based on two book, one of the 'Gang of Four', another one by Alexandrescu teases us about design patterns with modern C++. »
Pattern matching in C++ [Laurent Steff]
lundi 14 décembre 2020
« This talk covers quickly a lot of concepts (state machine, visitor pattern, algebraic data types, ...) and libraries (including Michael Park's variant and match). It gives access, for C++ developers who would fancy it, to declarative alternatives to the if-else chains. »
mercredi 12 juin 2019
« Comment créer un conteneur hétérogène en C++ avec std::variant (c++17) et le parcourir avec std::visit. »
jeudi 13 décembre 2018
« Un lien de veille de la semaine passée parlait de "type erasure", en mentionnant bien qu'il ne s'agissait pas du pattern C++ du même nom. Ca a piqué ma curiosité et je suis tombé sur ce lien très didactique qui explique ce pattern très intéressant qui permet notamment de stocker dans un même std::vector des objets ne dérivant pas d'une base commune. »
