jeudi 27 août 2026
« Rust seems to be there to stay in the Linux kernel. As I wanted to play and found the official documentation a bit terse, this article helped me all along to write my first rust module. »
Python bindings for Rust [Laurent STEFF]
jeudi 9 juillet 2026
« I was looking for pybind11 or nanobind equivalent for Rust, and found PyO3. Examples work like a charm, documentation seems neat, still have to try it on a real life project though 🙂. »
jeudi 18 juin 2026
« Il n'est pas possible de faire de la programmation orientée objet en Rust, mais voici une synthèse qui explique comment s'en passer. »
LLVM IR, again [Laurent STEFF]
jeudi 28 mai 2026
« LLVM IR was already introduced in a previous post. This one has a different approach, it focuses more on practical example of the IR itself than the architecture and design decisions behind LLVM. Be ready to explore the place in LLVM compilers where optimizations take place, between the AST (frontend) and the assembly (backend). »
jeudi 16 avril 2026
« Spotted on Slashdot, many features on this new release, for example on the file systems, with ext4 concurrent writes, or related to Rust, with the official ending of the Rust experiment. Be wary that it is a two pages article ;). »
TypeState Pattern in Rust [Laurent Steff]
jeudi 12 mars 2026
« If you already created a network related API you certainly encountered this kind of issue : how to enforce the fact that the 'send' method could be called only if the 'connect' one has been successfully called before ? Here is a simple example on how you could tackle this with Rust. For more complete details you could also have a look at this post which also explains why this pattern is more easy to implement in Rust than in C++. »
jeudi 15 janvier 2026
« Un livre en ligne pour apprendre à implémenter un langage de programmation à travers des exemples pas-à-pas utilisant le langage Rust. »
How uv got so fast [Vincent]
jeudi 8 janvier 2026
« Un petit retour en arrière pour expliquer ce qui a permis au gestionnaire de paquets uv de naître, et sur les choix de design de l'outil qui lui permettent d'être bien plus rapide que ses concurrents historiques. »
typst [Vincent]
jeudi 20 novembre 2025
« typst est un outil développé en rust qui se veut aussi puissant que LaTeX, tout en étant plus facile à apprendre et à utiliser. typst permet également de scripter à l'intérieur de son document. Le tutoriel, le tableau de correspondance des commandes LaTeX ainsi que le support par Pandoc laisse présager un avenir sérieux à ce concurrent. »
jeudi 19 juin 2025
« Bien que la dette technique de ce « jeune » compilateur ne soit pas importante, des réflexions sur le pourquoi ce n'est pas facile d'améliorer les performances du compilateur Rust. »
jeudi 19 juin 2025
« Un livre conçu pour les développeurs C++ avec des exemples de code Rust pour des concepts utilisés en C++. »
jeudi 20 mars 2025
« It was one of the latest weeks big news : TypeScript is migrating to Go. But why, why not staying as it is, why not switching to C#, Rust, or another language ? Here Anders Hejlsberg, one of the co-creator of TypeScript explains almost everything. One figure struck me, if I understood well, speaking of why alternatives to TypeScript compiler struggled to attain critical mass : "we have about one hundred man year invested in TypeScript". Anyway, let's hope they will find a migration path smoother than other languages, as TypeScript 6 (JS) and TypeScript 7 (native, written in Go) may well live a long time alongside one another. »
jeudi 13 mars 2025
« Un article en 2 parties (le deuxième article) qui explique ce qu'est l'eBPF, et comment écrire son premier programme eBPF en rust grâce au framework Aya. »
jeudi 13 février 2025
« Un article qui décrit la théorie des patchs pour mieux gérer les conflits de fusion pour les systèmes de gestion de version. Une version codée en Rust est disponible sur le projet Pijul, un sérieux concurrent pour Git ? »
jeudi 12 septembre 2024
« L'auteur explique son expérience avec Rust où quelques dépendances directes vers des bibliothèques impliquent des dizaines d'autres dépendances, avec pour conséquence une fragilité concernant la sécurité et la maintenance. Il indique comment il a contourné la dépendance vers certaines bibliothèques. »
jeudi 23 mai 2024
« Apprendre Rust avec des exercices de programmation. »
Learn Rust the Dangerous Way [Benjamin Nguyen-Van-Yen]
jeudi 21 mars 2024
« Une série d'articles ludiques et détaillés sur la conversion d'un programme C en Rust, en rajoutant progressivement plus de garanties au code sans perdre en performance. La version finale en Rust idiomatique est même plus rapide ! »
jeudi 14 mars 2024
« Certaines des dernières évolutions du langage Java sont clairement inspirées du langage Rust. »
jeudi 29 février 2024
« Un installeur/solveur de packages Python ultra-rapide écrit par l'équipe qui a élaboré Ruff. »
jeudi 25 janvier 2024
« FreeBSD est en train de peser le pour et le contre d'une réécriture de son code en Rust, et d'améliorer les performances de compilation pour ses besoins. »
jeudi 7 décembre 2023
« Une enquête à base de strace, perf et eBPF pour comprendre des problèmes de performance sur un CPU bien spécifique. »
jeudi 30 novembre 2023
« OCaml for Algebraic Data Types and pattern matching, C++ for references and RAII, Ruby for closures' syntax ... This very short page describes where Rust comes from. »
« There is no built-in runtime for async Rust for now, and Tokio is one of the popular external crate we can use. This old but, I believe, still up to date article gives a view of how Tokio works, from the bottom up. »
Effective Rust [Laurent Steff]
jeudi 16 novembre 2023
« If you got through the Rust "Book" and still want to explore further, here is a documentation inspired by Scott Meyers' Effective C++ books. »
jeudi 21 septembre 2023
« Nushell est un shell entièrement écrit en rust, multi-plateforme, qui reprend le principe des pipelines du bash, mais il est aussi capable de prendre en entrée des données structurées (JSON, YAML, SQLite, Excel...). Un système de greffons permet même de faire évoluer les commandes. »
Writing an OS in Rust [Laurent Steff]
jeudi 29 juin 2023
« This blog series cover almost everything, code included. »
[os, rust]
vendredi 2 juin 2023
« Article montrant la démarche pour optimiser un code scientifique Python en utilisant Rust, PyO3 et des outils de profiling. Les gains en performance avec une implementation en Rust des parties Python les plus lentes sont impressionnants, sans contrepartie sur l'interface utilisateur (même API Python). »
vendredi 26 mai 2023
« Cet article donne quelques exemples pour améliorer son code Python en s'inspirant de Rust: "type hints", "dataclasses", etc »
jeudi 11 mai 2023
« rattler-build est une réimplémentation en rust du célèbre conda-build, outil qui permet de construire les paquets conda à partir d'une recette »
WebGPU for WebGL developers [Laurent Steff]
vendredi 14 avril 2023
« A very detailed article about differences between WebGL and WebGPU for developers, including their shading languages. As quoted from the article "GLSL is C/C++ like. WGSL is Rust like." »
Algebraic Data Types 101 [Laurent Steff]
vendredi 31 mars 2023
« Even wonder what are Algebraic Data Types, sum types, product types ? This post explains a lot, with examples on various programming languages like C++, Switf, Haskell, and mostly Rust. »
jeudi 23 mars 2023
« From this page: "By default, Rust optimizes for execution speed, compilation speed, and ease of debugging rather than binary size, since for the vast majority of applications this is ideal. But for situations where a developer wants to optimize for binary size instead, Rust provides mechanisms to accomplish this." »
jeudi 23 mars 2023
« Thoughts about memory safety in various programming languages. This article also points to a detailed comparison between Zig and Rust. »
[c, rust, zig]
jeudi 23 mars 2023
« Zig is a fairly new programming language and toolchain which aims mostly to be a simple successor to C. This article explains a bit the why of its existence. »
jeudi 16 février 2023
« Related or not to this NSA's paper, the C++ community and it's creator Bjarne Stroustrup want to try to change the language to mitigate memory safety concerns. »
jeudi 5 janvier 2023
« The author shows quickly that the question is tricky and tries instead to answer those two questions: " What are functional programming principles?" And "Does Rust make it easy or hard to adhere to them?" »
jeudi 8 décembre 2022
« Benefits and costs of this adventure coming from an experienced software engineer new to Rust. »
[c, rust]
« Un article expliquant comment apprendre à programmer en Rust en utilisant Advent of Code, ChatGPT - le nouveau chat bot OpenAI - et GitHub copilot. »
On transpilers [Alexandre]
jeudi 1 septembre 2022
« Un article comparant des "transpilers" de C vers Go, Rust et Zig. Est-ce bientôt la fin du C ? »
« Started as an internal project by Google, Carbon should be by the end of the year a more open source project. It is announced with features like memory safety with dynamic bound checks, generics, compatibility with C++, and even an up to come package manager. »
[c, c++, rust]
A comparison of Rust and C [Laurent Steff]
jeudi 9 juin 2022
« Some interesting feedback from an ex C programmer about Rust. »
mercredi 2 février 2022
« Insights from data on O'Reilly's learning platform, some quotes that may be of interest:
  • "We start with an explosion of fantastic achievements that seem like science fiction—imagine, GPT-3 can write stories!"
  • "We know that C++ dominates game programming, but we suspect that it’s also coming to dominate embedded systems, which is really just a more formal way to say “internet of things.” We also suspect (but don’t know) that C++ is becoming more widely used to develop microservices."
jeudi 7 octobre 2021
« Il s'agit d'un témoignage en deux parties concernant le langage Rust et correspondant à deux étapes distinctes dans la découverte et la prise en main du langage. La deuxième partie est disponible ici. »
lundi 20 septembre 2021
« Pour ceux qui ont du mal avec les langages de programmation tout en anglais, Rouille est une version de Rust qui a été francisée. On appréciera l'humour du logo du projet. »
mardi 31 août 2021
« Ryan Dahl talks about programming languages, IDEs, frameworks and much more about software engineering. »
jeudi 15 juillet 2021
« Deno is a runtime for JavaScript and TypeScript, started by the creator of Node (Ryan Dahl) around 2018. Its stable release is a bit more than one year old. This article gives a bit more detail than the official documentation about the differences between Node and Deno. »
jeudi 24 juin 2021
« Google va financer un projet de réécriture de certaines parties du Kernel Linux en Rust pour en améliorer la sécurité. »
Rust support [Romain]
jeudi 15 avril 2021
« Un état des lieux de la proposition de support de Rust dans le noyau de Linux. »
jeudi 1 avril 2021
« Linus Torvalds n'exclut pas que Rust puisse être utilisé à titre expérimental dans le noyau Linux. »
jeudi 11 mars 2021
« Une page web dynamique qui présente de manière très synthétique des informations pratiques sur Rust »
mercredi 10 mars 2021
« A quite detailed overview for C++ programmers interested in Rust, and who prefer watching videos over reading 'The Book'. From Henrik Niemeyer at C++ London. »
Would Rust secure cURL? [Laurent Schneider]
jeudi 21 janvier 2021
« L'auteur reprend l'historique des bugs de la librairie cURL développée en C. Il montre l'intérêt de l'utilisation de Rust, qui aurait évité plus de la moitié des bugs. »
[c, rust]
jeudi 15 octobre 2020
« A fairly biased but yet interesting comparisons between those languages and their communities. »
[c, c++, go, rust]
mardi 22 septembre 2020
« L'article présente de manière très rapide 4 techniques d'implémentation qui permettent des gains significatifs (quel que soit l'algorithme implémenté) »
lundi 31 août 2020
« Depuis peu, le langage Rust supporte nativement les plateformes AVR (8bit) et cet article explique comment écrire, compiler et lancer une application de type hello-world sur une carte Arduino Uno. »
Comparing parallel Rust and C++ [Virgile Andréani [InBio]]
mercredi 13 novembre 2019
« Une fantastique démonstration d'optimisation, qui explique comment s'approcher de la vitesse théorique maximale d'un ordinateur en prenant en compte toutes les astuces de mémoire, jeu d'instructions et parallélisme. Dans le même domaine, ce cours peut également être intéressant. »
mercredi 10 janvier 2018
« Rust pour remplacer C et C++ ? Echec d'H265 et fin des codecs propriétaires ? Les prédictions pour 2018 de Christian F.K. Schaller, "Senior Manager for Desktop" chez Red Hat »
mercredi 15 novembre 2017
« Juggernaut est une bibliothèque implémentée en Rust qui permet de construire des applications web pour former et évaluer des réseaux neuronaux. Il y a aussi une page de démo qui utilse React.js, D3.js et WebAssembly. »
« Un excellent article, très bien illustré, présentant la refonte de parties centrales de la dernière version de Firefox, sortie le 14 novembre, pour le rendre encore plus rapide et stable. »
vendredi 4 mars 2016
« Une comparaison des langages Java et Rust. »
Two weeks of Rust [Maxence]
vendredi 22 janvier 2016
« Un retour d'expérience sur une première utilisation du langage Rust. »
